xJayx
Mar 21, 2018Aspirant
CM1000 RCN Firmware
I am seeing some issues with my 1GB internet service from RCN recently. The only difference I see is that the ISP has upgraded the modem to v3.01.04 firmware. I did not see these concerns with the 2....
xJayx
Mar 22, 2018Aspirant
Slower Speeds on peripherals. I was seeing 800+ speeds on iphone before, now 300. When I connected to Wifi (normally use ethernet) on my pc before I was getting speeds close to 900, now I get 50. Recently, my tv takes time sometimes to connect to a request, and sometimes will stop functioning. When I stream on my ipad the picture gets blurry for like 20 minutes. As well as lower speeds the speeds do not seem consistent. The only thing that has changed is the firmware on the modem (I have a netgear nighthawk I also loaded the latest firmware on this.)It seems I had better speeds and stability with the prior 2.01.xx version I was running and want to make certain that the 3.01.04 version is applicable to my RCN ISP modem. I have a separate Nighthawk router, this was something RCN specced to me when I started service.
Thanks
vkdelta
Mar 22, 2018NETGEAR Employee Retired
reboot the modem and connect your laptop directly to the modem and test the speeds. You have upgraded 2 devices at the same time in the network.
also, please post DOCSIS EVENT LOG and CONNECTION Table from the modem.
- xJayxMar 22, 2018Aspirant
The question I am asking is which version of firmware should be on my RCN Modem? The one listed for "all other companies" on your web page (as copied above), or the one listed as the correct firmware version for "Comcast"? (please see prior comment for copy of online chart referenced)?
I rebooted modem and router again, and acheived a download speed of 350 for the gig service I subscribe to on the pc. After initial install I was seeing a steady 960 +. This is with the network cable connected directly to the pc.
I will repost modem specs again below post latest reboot.
I am asking which version of firmware is correct for RCN service?
Thank You
Frequency start Value This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. Starting Frequency <tabindex=-1>Startup Procedure Procedure Status Comment Acquire Downstream Channel 609000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Security Enable BPI+ IP Provisioning Mode Honor MDD IPv4 only <tabindex=-1>Downstream Bonded Channels Channel Lock Status Modulation Channel ID Frequency Power SNR / MER Unerrored Codewords Correctable Codewords Uncorrectable Codewords 1 Locked QAM256 14 609000000 Hz -4.3 dBmV 41.7 dB 66564968 0 0 2 Locked QAM256 1 531000000 Hz -4.1 dBmV 41.9 dB 64601823 0 0 3 Locked QAM256 2 537000000 Hz -4.2 dBmV 41.7 dB 64610668 0 0 4 Locked QAM256 3 543000000 Hz -4.2 dBmV 41.9 dB 64620860 0 0 5 Locked QAM256 4 549000000 Hz -4.3 dBmV 41.6 dB 64630449 0 0 6 Locked QAM256 5 555000000 Hz -5.2 dBmV 41.5 dB 64648340 0 0 7 Locked QAM256 6 561000000 Hz -4.8 dBmV 41.8 dB 64657096 0 0 8 Locked QAM256 7 567000000 Hz -4.7 dBmV 41.7 dB 64666583 0 0 9 Locked QAM256 8 573000000 Hz -5.0 dBmV 41.6 dB 64675961 0 0 10 Locked QAM256 9 579000000 Hz -4.4 dBmV 41.7 dB 64684910 0 0 11 Locked QAM256 10 585000000 Hz -4.3 dBmV 41.8 dB 64694412 0 0 12 Locked QAM256 11 591000000 Hz -4.4 dBmV 41.6 dB 64703205 0 0 13 Locked QAM256 12 597000000 Hz -4.3 dBmV 41.6 dB 64712365 0 0 14 Locked QAM256 13 603000000 Hz -4.3 dBmV 41.6 dB 64719507 0 0 15 Locked QAM256 15 615000000 Hz -4.5 dBmV 40.7 dB 64725985 0 0 16 Locked QAM256 16 621000000 Hz -4.6 dBmV 41.1 dB 64731922 0 0 17 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 18 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 19 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 20 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 21 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 22 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 23 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 24 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 25 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 26 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 27 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 28 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 29 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 30 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 31 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 32 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 <tabindex=-1>Upstream Bonded Channels Channel Lock Status Modulation Channel ID Frequency Power 1 Locked ATDMA 3 32996000 Hz 44.0 dBmV 2 Locked ATDMA 4 25396000 Hz 44.0 dBmV 3 Not Locked Unknown 0 0 Hz 0.0 dBmV 4 Not Locked Unknown 0 0 Hz 0.0 dBmV 5 Not Locked Unknown 0 0 Hz 0.0 dBmV 6 Not Locked Unknown 0 0 Hz 0.0 dBmV 7 Not Locked Unknown 0 0 Hz 0.0 dBmV 8 Not Locked Unknown 0 0 Hz 0.0 dBmV <tabindex=-1>Downstream OFDM Channels Channel Lock Status Modulation / Profile ID Channel ID Frequency Power SNR / MER Active Subcarrier Number Range Unerrored Codewords Correctable Codewords Uncorrectable Codewords 1 Locked 0, 1, 2, 3 159 634000000 Hz -3.7 dBmV 28.0 dB 646 ~ 3449 94181650 94168651 0 2 Not Locked 0 0 0 Hz -6.2 dBmV 0.0 dB 0 ~ 4095 0 0 0 <tabindex=-1>Upstream OFDMA Channels Channel Lock Status Modulation / Profile ID Channel ID Frequency Power 1 Not Locked Unknown 0 0 Hz 0 dBmV 2 Not Locked Unknown 0 0 Hz 0 dBmV Current System Time: Fri Mar 23 04:29:44 2018
Help Center
Show/Hide Help Center - vkdeltaMar 22, 2018NETGEAR Employee Retired
RCN does not specifically have a certification program. However, they are in our portal for FW distribution and they would have got same latest FW as Comcast. they can download the FW and push it to their customers. Can you please confirm they sent the correct modem config file when they pushed the new FW? if they have changed the config file to lower tier, it will provide you lower throughput.
- xJayxMar 24, 2018Aspirant
yes, they have the latest firmware as noted on netgear specs posted above for comcast loaded on my modem.
What I am saying is that when the 2.xx.xx firmwareware was on my modem I got great speeds on my peripherals. Today I speed tested my IPAD on the 3.xx.xx and got a dl speed of ten. Yesterday this was @ 120. I did not see this type of inconsistency when the 2.xx.xx firmware that was on the modem previously. Iphone speeds are 1/3 of what they were post install
However, if both netgear and rcn are recommending the 3.xx.xx version of software, and there is no way I can test to see if the firmware is causing the issue, I will call them and see if I can rent an arris modem for a month to see if my speeds go back to what they were.
What I had needed to know was if they had the recommended firmware loaded, and it appears that they do.
Thank You for your help and patience.
