Justin81's avatar
Justin81
CM1000 slow Ethernet , faster WiFi - comcast 1 Gig
Hi,
I’m a Comcast customer, just bought the 1 Gig Internet, and bought a CM1000 and Google WiFi. I’m getting roughly 160 mbps down via Ethernet and 500 mbps down via WiFi. Comcast is at a complete loss as to why this is the case. I’ve done multiple factory resets . Using Cat 5 cable.
Any theories here would be great. Super frustrated
  • QOS/DPI turned off in your router?
    Drivers updated for your NIC card ?
      • BigQuark's avatar
        BigQuark
        Guide
        The QOS setting will be on a menu inside you router. inside you router.  Where at really depends on the router model.
        To upgrade your NIC Card Driver you'll need to get into windows device manager, find your network adapter  and either Auto update or manually update the driver.
        Hope this helps.
  • vkdelta's avatar
    vkdelta
    NETGEAR Employee Retired
    always verify it directly connected to CM1000 after a fresh power cycle to confirm you are getting close to a gigE performance.
      • vkdelta's avatar
        vkdelta
        what speeds do you see with your PC directly connected to modem?
        is your PC/Laptop spec high-end and you are not using USB<>ETH adapters?
        Please post connection table from the modem.
