Cheeky73
Jul 08, 2018Aspirant
CM1000 User Management vs SB8200
Just bought a SB8200 to go with my brand new Nighthawk S8000 and Nighthawk X10. You might wonder why a SB to pair up with Netgear. Truthfully, I've been a long time user and this was an upgrade. H...
vkdelta
Jul 08, 2018NETGEAR Employee Retired
CM1000 - FW upgrades - no, you will not be able to upgrade the FW yourself.
passwords - check page 18/19 on the user manual if this is what you are expecting - http://www.downloads.netgear.com/files/GDC/CM1000/CM1000_All_MSOs_UM_EN.pdf
- Cheeky73Jul 09, 2018Aspirant
Does it matter security wise if I can't change the login information to my modem since it's not a router as well?
