Ron-Richardson's avatar
Aug 30, 2018
CM1000 Xfinity - Upload Speeds
Just installed the CM1000 (to wired desktop) and I have Xfinity's 250M down / 10M up.   When I run the Xfinity speed test, I get about 280M / 11M.   That looks great.  Then I upload files via FTP or file upload in cPanel, both to four different hosting services, I consistently get about 1.4M upload speed.  I don't get it...  I really wanted faster upload speeds.  Is it Xfinity?
  • vkdelta's avatar
    vkdelta
    NETGEAR Employee Retired
    is it 1.4MBps or 1.4 Mbps?
    It might be cPanel limitation or you need to put multiple transfer threads in the FTP tool.
    • Ron-Richardson's avatar
      Ron-Richardson
      It's 1.4MB.   Rookie mistake.  And, now I see that speedtests are in Mb.  So, that mystery solved.  I am getting the upload speed that I should.
      But, I'm intrigued....  "multiple transfer threads in the FTP" ?   I'm using WinSCP.  Is that a feature of the FTP program or modem?  BTW, on Win 10.
      • vkdelta's avatar
        vkdelta
        yes, lot of folks forget MB vs Mb.
        not sure if winSCP supports it.
        https://winscp.net/tracker/513
        you are using SFTP and not traditional FTP.
        I believe Filezilla supports using FTP.
