Cinnaderp's avatar
Cinnaderp
CM1000v2 connectivity state access denied
My internet went down this morning so I went through some basics first, power cycles, reseating cables, soft resets and cmd line resets. I took my nighthawk router out of the line and directly connected to my CM1000v2. The modem is showing solid upstream/downstream and online with activity so I checked the internal status. The connection is showing good but looking inside the cable connection I am showing connectivity state stuck on in progress and access denied for the comment. I am running Hardware Version 2.02 with firmware version V6.01.07 currently. I did go through a factory reset on the modem and swapped out my ethernet with a known good cable with no change. I have the event log before and after the reset attached. Looking for advice on this while I parse through the errors myself to see what I can do because cox is all shoulders on this.
  • It does look like my upstream is having a major power issue. Everything I am reading is that this should less than 37 dBmV. if this is my main concern what should I do about this because swapping modems likely would not resolve a power issue on the line. This has been running solidly for well over a year at this point so odd to see a power issue like this imo.
    <tabindex=-1>Upstream Bonded Channels</tabindex=-1>
    ChannelLock StatusModulationChannel IDFrequencyPower
    1LockedATDMA119300000 Hz50.0 dBmV
    2LockedATDMA225800000 Hz50.5 dBmV
    3LockedATDMA332200000 Hz50.5 dBmV
    4LockedATDMA438600000 Hz51.0 dBmV
    5Not LockedUnknown00 Hz0.0 dBmV
    6Not LockedUnknown00 Hz0.0 dBmV
    7Not LockedUnknown00 Hz0.0 dBmV
    8Not LockedUnknown00 Hz0.0 dBmV
