Ed-C
Jan 28, 2019Follower
CM1150V compatibility w/ ProSafe FVS318G
Tried to connect a Netgear ProSafe FVS316G router to the new CM1150v cable modem. The router will not auto connect to the modem and when you try to force the router by inputing all the Comcast ISP in...
vkdelta
Jan 28, 2019NETGEAR Employee Retired
Comcast does not accept STATIC IP for residential.
Just use DHCP on WAN and it should work. If not, Please post your setup info screenshots here.
Also, note to connect ONLY ONE devices behind CM1150V and not multiple.
