MikeCoolGuy17
Jun 17, 2019Aspirant
Cm1150V Issues With Channels Any Advise?
Hello New to the fourm. I'm haveing issues i have gig internet from comcast. ionly have 3 locked bonded upstream channels I know there should be 4. I only have 31 downstream channels locked. and some other ones all the numbers seems spratic. Hope someone can help me. I also had comcast provision it 5 times. not getting full gig speed seen it go to 650 tops. Thank you everyone.
Check for any cable line splitters and remove them if seen.
Contact the ISP and have them check there signal up to the modem.
- MikeCoolGuy17Aspirant
Thank you for that. Ive benn in contact with comcast they say everything is good. I tried talking with them 4 different times and all say is good. Ido have a splitter there as one goes to my cable box. but tried it with out it with the same results. Any other suugestions? Thanks.
Try a different CM modem. It's possible that your one unit could be faulty.
