Greg76's avatar
Greg76
Tutor
Nov 22, 2020
CM1150V Voice Not Working
I purchased the CM1150V from netgear to replace the Altice modem from Optimum so I could fully access my smart home systems.  The modem was provisioned by Optimum when I called and internet works just as it should. However I cannot get my phone service to work.  It was working on the Altice modem immediately before.  Optimum says it is set up on thier side.  Is there anything I need to do to get it working or could there be something wrong with my modem?  Any help appreciated.
  • FURRYe38's avatar
    Either ISP or a tech needs to check the phone lines in your home. You'll need to contac the ISP for help in this. If this worked on a different ISP and isn't working on the different ISP, then the newer ISP needs to look into this.
    • Greg76's avatar
      Greg76
      Tutor
      It is the same ISP (Optimum).  The only difference here is the modem.
      • FURRYe38's avatar
        Contact NG support as well.
