Boombar
Jul 02, 2020Tutor
CM1150v with xfinity dropps speeds soon after a reboot
I have cm1150v modem with xfinity 1Gb service.Firmware version is set by comcast, v2.02.04.
I'm using 2 LAN port aggregation to RAX80 wifi router, they are both located near eachother.
I measure internet speed from my Nighthawk rax80 app on my phone. After fresh reboot of the cm1150v it shows the speeds ~1GBps. After 24 hours the speed drops to 20Mbps. Rebooting the modem gets it to 1GB/s again and the cycle repeats.
Any clue as to why this is hapening? I talked to Comcast but couldn't get further than suggested reboot. They asked if the CAT6 cable beteen the modem and router could be a problem...it is not. They confirmed the firmware version is v2.02.04. Is there some setup issue on the router that i could take a look at? Or is it possible, and risking sounding like conspiracy nut, that Comcast is deliberately slowing down my speeds?
Rebooting the modem every day gets old after a while...
Its an issue with link aggregation. It seems like both netgear and arris have had issues with link aggregation and speed drops.
Its a great idea in concept but performs poorly on consumer devices.
I'd disable link aggregation and just run it with a standard 1 gig connection.
I switched from a cm1100 to the CAX80 just for the 2.5g ethernet port and the issues with link aggregation.
- BoombarTutor
I decided to change the 2 cables for agregation with 2 that are identical, in lenght and manufacturer. I also put aluminum foil between the wifi and the modem.
Surprisingly the Modem has been up to speed for couple of days now. If it drops again, i'll disconect the agregation and report back.Thank you!
- BoombarTutor
After few days with new cables for 2 LAN port aggregation, the speed droped again from >1gbs to ~20mbs. I disconnected the aggregation and now the speed lingers around 500mbs.
Sucks.
You could put it on one of those Christmas light timers, and just reboot it every morning between 4am and 4:30am.
Boombar wrote:Rebooting the modem every day gets old after a while...
- BoombarTutor
Hey,thats an idea! i might as well try that. Cheers!
- I am having a similar problem with a refurbished CM1150V and a new RAX120 router. I haven’t isolated the slow down to the modem, but others have seen ping times soar, packet loss surge, and throughput drop enough to get kicked from games.
I am using LA as well. There is also a security appliance in the setup, but it is a year old and has never behaved this way, despite numerous firmware updates. But LA is new for all.
Today, I powered cycled all the networking equipment and speed came right back. I have yet to confirm the problem is the modem.
