BreedTN's avatar
BreedTN
Tutor
Jun 08, 2019
Cm1200 losing power
I had this modem for about a days. It turns itself off. Please help!
  • You could exchange it where ever you purchased it. Most placed have an exchange policy with a certain window. If its only a couple days, you should still be within that window but check with wherever you purchased it.
  • plemans's avatar
    Is it plugged in correct both to the outlet and the back of the modem? If it is, I'd return/exchange it. You might have gotten a defective item. If you're outside of your return window, you can open a support ticket with Netgear for warranty exchange.
    • BreedTN's avatar
      BreedTN
      Tutor
      I have had it only a week. Hiw do I get an exchange?
      • plemans's avatar
  • michaelkenward's avatar
    michaelkenward
    What does that mean? The wifi dies? The Internet goes down? The power LED goes off?
    Tell us more.
