hubbles_law
Dec 14, 2022Aspirant
CM1200 losing speed right after reboot
Background - about 48 hours ago, I noticed my internet slow down and struggling. Since then whenever I run a speed test I wind up with ~30Mbps Down | ~20Mbps Up and should be around 1Gbps Down, I called up RCN.
I moved the modem closer to the wall and tested it hardlined to the computer. I performed countless reboots and a few factory resets. While looking over http://il.speedtest.rcn.net/merlin/ - I see:
The modem is operating in Partial mode. This may negatively impact service and could indicate a problem with one or more Upstream or Downstream channels.
Last Connection Status: Partially operational
OFDM impairment. Channel disabled by modem.
I only see 20 of 32 Down Channels locked, and on the event log under 192.168.100.1 I have noticed event code 20 and 22 seem to populate regularly.
NOW - the strange part. Whenever I reboot the modem, after it connects to the internet I can run a speed test and will see around 1Gbps down for the first minute or so if I run multiple tests back to back. But then it starts to drop and eventually settles back around ~30Mbps... I can recreate this behavior multiple times but the slow down doesn't seem to happen at the same intervals, at least not from what I can tell.
I just spent 4 hours with the service tech who checked all the lines, decided to replace the line to the house, and told me they are seeing everything from their end working just fine. After they did so I am seeing better power but the problem persists for my Netgear CM1200. They even tested their Hiltron CODA-5712 which seemed to be steady for around 15m with 1Gbps down speeds. So my ISP is saying its a problem with my modem.
Which is on firmware V3.02.01 which should be what they are using.
Has anyone seen anything like this? Is my 2 year old modem hardware failing?
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-routerBe sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model of the host wifi router connected to the modem?Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html- hubbles_lawAspirant
Thanks for the reply, here are the details:
Enable Extended Upstream Transmit Power is Unchecked
Ethernet Port Aggregation is DISABLED
Startup Procedure Procedure Status Comment Acquire Downstream Channel 603000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Security Enabled BPI+ IP Provisioning Mode Honor MDD honorMdd(4) Downstream Bonded Channels (Partial Service) Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked QAM256 15 603000000 Hz 1.6 dBmV 39.4 dB 0 0 2 Locked QAM256 1 519000000 Hz 1.6 dBmV 39.7 dB 0 0 3 Locked QAM256 2 525000000 Hz 1.6 dBmV 39.6 dB 0 0 4 Locked QAM256 3 531000000 Hz 1.7 dBmV 39.6 dB 0 0 5 Locked QAM256 4 537000000 Hz 1.8 dBmV 39.7 dB 0 0 6 Locked QAM256 5 543000000 Hz 1.6 dBmV 39.7 dB 0 0 7 Locked QAM256 6 549000000 Hz 1.5 dBmV 39.7 dB 0 0 8 Locked QAM256 7 555000000 Hz 1.2 dBmV 39.6 dB 0 0 9 Locked QAM256 8 561000000 Hz 1.5 dBmV 38.9 dB 0 0 10 Locked QAM256 9 567000000 Hz 1.1 dBmV 39.5 dB 0 0 11 Locked QAM256 10 573000000 Hz 1.1 dBmV 39.1 dB 0 0 12 Locked QAM256 11 579000000 Hz 1.4 dBmV 39.5 dB 0 0 13 Locked QAM256 12 585000000 Hz 1.1 dBmV 39.4 dB 0 0 14 Locked QAM256 13 591000000 Hz 1.3 dBmV 39.4 dB 0 0 15 Locked QAM256 14 597000000 Hz 1.6 dBmV 39.5 dB 0 0 16 Locked QAM256 16 609000000 Hz 1.2 dBmV 39.3 dB 0 0 17 Locked QAM256 17 495000000 Hz 0.6 dBmV 39.6 dB 0 0 18 Locked QAM256 18 501000000 Hz 0.6 dBmV 39.5 dB 0 0 19 Locked QAM256 19 507000000 Hz 1 dBmV 39.5 dB 0 0 20 Locked QAM256 20 513000000 Hz 1.2 dBmV 39.6 dB 0 0 21 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 22 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 23 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 24 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 25 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 26 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 27 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 28 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 29 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 30 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 31 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 32 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 Upstream Bonded Channels Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 1 5120 Ksym/sec 36800000 Hz 50.5 dBmV 2 Locked ATDMA 2 5120 Ksym/sec 30350000 Hz 50.8 dBmV 3 Locked ATDMA 3 5120 Ksym/sec 23900000 Hz 50.8 dBmV 4 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 5 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 6 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 7 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 8 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV Downstream OFDM Channels Channel Lock
StatusModulation /
Profile IDChannel
IDFrequency Power SNR /
MERActive Subcarrier
Number RangeUnerrored
CodewordsCorrectable
CodewordsUncorrectable
Codewords1 Not Locked 0 0 0 Hz 0 dBmV 0.0 dB 0 ~ 4095 0 0 0 2 Not Locked 0 0 0 Hz 0 dBmV 0.0 dB 0 ~ 4095 0 0 0 Upstream OFDMA Channels Channel Lock Status Modulation / Profile ID Channel ID Frequency Power 1 Not Locked 0 0 0 Hz 0 dBmV 2 Not Locked 0 0 0 Hz 0 dBmV Time Priority Description Thu Dec 15 01:13:13 2022 Notice (6) CM-STATUS message sent. Event Type Code: 22; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:a0:db:28;CMTS-MAC=00:ca:e5:c8:c8:ea;CM-QOS=1.1;CM-VER=3.1; Thu Dec 15 01:12:09 2022 Notice (6) CM-STATUS message sent. Event Type Code: 20; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:a0:db:28;CMTS-MAC=00:ca:e5:c8:c8:ea;CM-QOS=1.1;CM-VER=3.1; Thu Dec 15 01:12:07 2022 Notice (6) CM-STATUS message sent. Event Type Code: 5; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:a0:db:28;CMTS-MAC=00:ca:e5:c8:c8:ea;CM-QOS=1.1;CM-VER=3.1; Thu Dec 15 01:11:56 2022 Warning (5) REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=08:36:c9:a0:db:28;CMTS-MAC=00:ca:e5:c8:c8:ea;CM-QOS=1.1;CM-VER=3.1; Thu Dec 15 01:11:53 2022 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=08:36:c9:a0:db:28;CMTS-MAC=00:ca:e5:c8:c8:ea;CM-QOS=1.1;CM-VER=3.1; Thu Dec 15 01:11:49 2022 Notice (6) TLV-11 - unrecognized OID;CM-MAC=08:36:c9:a0:db:28;CMTS-MAC=00:ca:e5:c8:c8:ea;CM-QOS=1.1;CM-VER=3.1; Thu Dec 15 01:11:48 2022 Error (4) Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=08:36:c9:a0:db:28;CMTS-MAC=00:ca:e5:c8:c8:ea;CM-QOS=1.1;CM-VER=3.1; Thu Dec 15 01:11:48 2022 Error (4) Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=08:36:c9:a0:db:28;CMTS-MAC=00:ca:e5:c8:c8:ea;CM-QOS=1.1;CM-VER=3.1; Thu Dec 15 01:11:48 2022 Error (4) Missing BP Configuration Setting TLV Type: 17.7;CM-MAC=08:36:c9:a0:db:28;CMTS-MAC=00:ca:e5:c8:c8:ea;CM-QOS=1.1;CM-VER=3.1; Thu Dec 15 01:11:48 2022 Error (4) Missing BP Configuration Setting TLV Type: 17.6;CM-MAC=08:36:c9:a0:db:28;CMTS-MAC=00:ca:e5:c8:c8:ea;CM-QOS=1.1;CM-VER=3.1; Thu Dec 15 01:11:48 2022 Error (4) Missing BP Configuration Setting TLV Type: 17.5;CM-MAC=08:36:c9:a0:db:28;CMTS-MAC=00:ca:e5:c8:c8:ea;CM-QOS=1.1;CM-VER=3.1; Thu Dec 15 01:11:48 2022 Error (4) Missing BP Configuration Setting TLV Type: 17.4;CM-MAC=08:36:c9:a0:db:28;CMTS-MAC=00:ca:e5:c8:c8:ea;CM-QOS=1.1;CM-VER=3.1; Thu Dec 15 01:11:48 2022 Error (4) Missing BP Configuration Setting TLV Type: 17.3;CM-MAC=08:36:c9:a0:db:28;CMTS-MAC=00:ca:e5:c8:c8:ea;CM-QOS=1.1;CM-VER=3.1; Thu Dec 15 01:11:48 2022 Error (4) Missing BP Configuration Setting TLV Type: 17.2;CM-MAC=08:36:c9:a0:db:28;CMTS-MAC=00:ca:e5:c8:c8:ea;CM-QOS=1.1;CM-VER=3.1; Thu Dec 15 01:11:48 2022 Error (4) Missing BP Configuration Setting TLV Type: 17.1;CM-MAC=08:36:c9:a0:db:28;CMTS-MAC=00:ca:e5:c8:c8:ea;CM-QOS=1.1;CM-VER=3.1; Thu Dec 15 01:11:47 2022 Warning (5) DHCP WARNING - Non-critical field invalid in response ;CM-MAC=08:36:c9:a0:db:28;CMTS-MAC=00:ca:e5:c8:c8:ea;CM-QOS=1.1;CM-VER=3.1; Time Not Established Notice (6) Honoring MDD; IP provisioning mode = IPv4 Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=08:36:c9:a0:db:28;CMTS-MAC=00:ca:e5:c8:c8:ea;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:a0:db:28;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; - FURRYe38Guru - Experienced User
You have lots of errors and criticals that the ISP needs to review and resolve.
Be sure to have them check the other suggestions as well.
