spoonbandits's avatar
spoonbandits
CM1200 only getting 120mbps
Anyone have any idea on how to resolve this?
I've got a brand new CM1200 - called the cable company and gave them MAC address, they said no compatibility problems. I've got port 1 plugged in to my Asus RT-N66R, but I am only getting 120mbps.
My previous Arris cable modem (ISP provided) was getting ~1gbps no problem, so I don't think its a router issue.
Does the modem require a router that supports link aggregation to get the ~1gbps?
Any help in ways to troubleshoot is greatly appreciated.
  • FURRYe38's avatar
    Who is your ISP?
    Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly. Have them ensure the channels they are supporting are being locked in on the modem.
    Be sure there are no coax cable line splitters in the between the modem and ISP service box.
    Be sure your using good quality RG6 coax cable up to the modem.
  • FURRYe38's avatar
    Disconnect the ASUS router and directly connect 1 wired 1Gb ethernet supported PC to the CM modem. Power off the modem for 1 minute then back on. Check the speeds with Ooklas installable speed test app with the PC.
    Please post a copy and paste of the modems connection status page.
    • spoonbandits's avatar
      spoonbandits
      I followed the recommend steps, still only getting 120mpbs on my connected PC.
      I noticed that not all channels are "Locked" in the status screen:
