Benny1053's avatar
Mar 22, 2022
CM2000 Fails to Activate - Xfinity
Model wouldn't let me select CM2000, unsure why but to the story....
I purchased a CM2000 back in December and started having issues with it in February, after ISP came out and checked the line the only way I could get my internet to work was by using different modems. Downstream voltages were ~7 and below and Upstream 34-35. Internet would constantly drop out every 3-5 minutes.
Eventually Netgear put me in the RMA process and my unit was replaced with a certified remanufactured unit, only the unit was replaced not power adapters etc. I attempted to activate the unit myself and through Xfinity support but they are unable to see the unit online. Again, my other modem still works just fine. I'm not sure where to go from here, any advice would be greatly appreciated. I can come up with some event logs if that would help?
  • plemans's avatar
    Event logs might help as well as the cable connections page.
    • Benny1053's avatar
      Benny1053
      Tutor
      I'll work on these this evening, I'll have to switch back to the CM2000 to get the logs. Thanks for the quick response!
      Benny1053
      Tutor
      Cable Connection
      Cancel Apply
      Frequency start Value
      This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect.
      Starting Frequency
      0
      Startup Procedure
      Procedure Status Comment
      Acquire Downstream Channel 507000000 Hz Locked
      Connectivity State OK Operational
      Boot State OK Operational
      Security Enabled BPI+
      Downstream Bonded Channels
      Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables
      1 Locked QAM256 5 507000000 Hz 6.8 dBmV 41.3 dB 0 0
      2 Locked QAM256 2 489000000 Hz 7.4 dBmV 41.5 dB 0 0
      3 Locked QAM256 3 495000000 Hz 7.3 dBmV 41.4 dB 0 0
      4 Locked QAM256 4 501000000 Hz 7.0 dBmV 41.3 dB 0 0
      5 Locked QAM256 6 513000000 Hz 6.8 dBmV 41.3 dB 0 0
      6 Locked QAM256 7 519000000 Hz 6.5 dBmV 41.0 dB 0 0
      7 Locked QAM256 8 525000000 Hz 6.3 dBmV 40.8 dB 0 0
      8 Locked QAM256 9 531000000 Hz 6.4 dBmV 41.0 dB 0 0
      9 Locked QAM256 10 537000000 Hz 6.2 dBmV 41.0 dB 0 0
      10 Locked QAM256 11 543000000 Hz 6.0 dBmV 40.9 dB 0 0
      11 Locked QAM256 12 549000000 Hz 6.0 dBmV 40.8 dB 0 0
      12 Locked QAM256 13 555000000 Hz 6.2 dBmV 40.8 dB 0 0
      13 Locked QAM256 14 561000000 Hz 6.1 dBmV 40.8 dB 0 0
      14 Locked QAM256 15 567000000 Hz 5.8 dBmV 40.7 dB 0 0
      15 Locked QAM256 16 573000000 Hz 5.7 dBmV 40.5 dB 0 0
      16 Locked QAM256 17 579000000 Hz 5.7 dBmV 40.4 dB 0 0
      17 Locked QAM256 18 585000000 Hz 5.8 dBmV 40.4 dB 0 0
      18 Locked QAM256 19 591000000 Hz 5.7 dBmV 40.5 dB 0 0
      19 Locked QAM256 20 597000000 Hz 5.6 dBmV 40.5 dB 0 0
      20 Locked QAM256 21 603000000 Hz 5.6 dBmV 40.4 dB 0 0
      21 Locked QAM256 22 609000000 Hz 5.8 dBmV 40.4 dB 0 0
      22 Locked QAM256 23 615000000 Hz 5.9 dBmV 40.4 dB 0 0
      23 Locked QAM256 24 621000000 Hz 6.0 dBmV 40.5 dB 0 0
      24 Locked QAM256 25 627000000 Hz 5.8 dBmV 40.4 dB 0 0
      25 Locked QAM256 26 633000000 Hz 5.8 dBmV 40.3 dB 0 0
      26 Locked QAM256 27 639000000 Hz 5.7 dBmV 40.2 dB 0 0
      27 Locked QAM256 28 645000000 Hz 5.7 dBmV 40.3 dB 0 0
      28 Locked QAM256 30 651000000 Hz 5.5 dBmV 40.3 dB 0 0
      29 Locked QAM256 31 657000000 Hz 5.4 dBmV 40.2 dB 0 0
      30 Locked QAM256 32 663000000 Hz 4.9 dBmV 39.9 dB 0 0
      31 Locked QAM256 33 669000000 Hz 4.7 dBmV 39.8 dB 0 0
      32 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0
      Upstream Bonded Channels
      Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power
      1 Locked ATDMA 5 5120 35600000 Hz 34.3 dBmV
      2 Locked ATDMA 6 5120 29200000 Hz 34.5 dBmV
      3 Locked ATDMA 7 5120 22800000 Hz 34.3 dBmV
      4 Locked ATDMA 8 5120 16400000 Hz 34.0 dBmV
      5 Locked ATDMA 10 1280 39600000 Hz 34.5 dBmV
      6 Not Locked Unknown 0 0 0 Hz 0.0 dBmV
      7 Not Locked Unknown 0 0 0 Hz 0.0 dBmV
      8 Not Locked Unknown 0 0 0 Hz 0.0 dBmV
      Downstream OFDM Channels
      Channel Lock
      Status Modulation /
      Profile ID Channel
      ID Frequency Power SNR /
      MER Active Subcarrier
      Number Range Unerrored
      Codewords Correctable
      Codewords Uncorrectable
      Codewords
      1 Locked 0 ,1 ,2 ,3 37 690000000 Hz 4.8 dBmV 39.3 dB 1108 ~ 2987 174627 174549 0
      2 Not Locked 0 0 0 Hz 0 dBmV 0.0 dB 0 ~ 4095 0 0 0
      Upstream OFDMA Channels
      Channel Lock Status Modulation / Profile ID Channel ID Frequency Power
      1 Not Locked 0 0 0 Hz 0 dBmV
      Extended Upstream Transmit Power
      Current System Time:Tue Mar 22 15:43:12 2022
      System Up Time:00:00:54
      Help CenterShow/Hide Help Center
      Event Log
      Clear Log Refresh
      Time Priority Description
      Tue Mar 22 15:43:00 2022 (Notice (6)) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=80:cc:9c:dd:37:d0;CMTS-MAC=00:01:5c:8d:18:58;CM-QOS=1.1;CM-VER=3.1;
      Tue Mar 22 15:42:55 2022 (Notice (6)) TLV-11 - unrecognized OID;CM-MAC=80:cc:9c:dd:37:d0;CMTS-MAC=00:01:5c:8d:18:58;CM-QOS=1.1;CM-VER=3.1;
      Time Not Established (Notice (6)) Honoring MDD; IP provisioning mode = IPv6
      Time Not Established (Critical (3)) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=80:cc:9c:dd:37:d0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      Tue Mar 22 15:12:25 2022 (Notice (6)) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=80:cc:9c:dd:37:d0;CMTS-MAC=00:01:5c:8d:18:58;CM-QOS=1.1;CM-VER=3.1;
      Tue Mar 22 15:12:20 2022 (Notice (6)) TLV-11 - unrecognized OID;CM-MAC=80:cc:9c:dd:37:d0;CMTS-MAC=00:01:5c:8d:18:58;CM-QOS=1.1;CM-VER=3.1;
      Mon Mar 21 20:13:16 2022 (Notice (6)) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=80:cc:9c:dd:37:d0;CMTS-MAC=00:01:5c:8d:18:58;CM-QOS=1.1;CM-VER=3.1;
      Mon Mar 21 20:13:11 2022 (Notice (6)) TLV-11 - unrecognized OID;CM-MAC=80:cc:9c:dd:37:d0;CMTS-MAC=00:01:5c:8d:18:58;CM-QOS=1.1;CM-VER=3.1;
      Time Not Established (Critical (3)) No Ranging Response received - T3 time-out;CM-MAC=80:cc:9c:dd:37:d0;CMTS-MAC=00:01:5c:8d:18:58;CM-QOS=1.1;CM-VER=3.1;
      Mon Mar 21 20:01:47 2022 (Notice (6)) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=80:cc:9c:dd:37:d0;CMTS-MAC=00:01:5c:8d:18:58;CM-QOS=1.1;CM-VER=3.1;
      Mon Mar 21 20:01:42 2022 (Notice (6)) TLV-11 - unrecognized OID;CM-MAC=80:cc:9c:dd:37:d0;CMTS-MAC=00:01:5c:8d:18:58;CM-QOS=1.1;CM-VER=3.1;
      Mon Mar 21 19:53:30 2022 (Notice (6)) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=80:cc:9c:dd:37:d0;CMTS-MAC=00:01:5c:8d:18:58;CM-QOS=1.1;CM-VER=3.1;
      Mon Mar 21 19:53:25 2022 (Notice (6)) TLV-11 - unrecognized OID;CM-MAC=80:cc:9c:dd:37:d0;CMTS-MAC=00:01:5c:8d:18:58;CM-QOS=1.1;CM-VER=3.1;
      Mon Mar 21 19:50:22 2022 (Notice (6)) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=80:cc:9c:dd:37:d0;CMTS-MAC=00:01:5c:8d:18:58;CM-QOS=1.1;CM-VER=3.1;
      Mon Mar 21 19:50:17 2022 (Notice (6)) TLV-11 - unrecognized OID;CM-MAC=80:cc:9c:dd:37:d0;CMTS-MAC=00:01:5c:8d:18:58;CM-QOS=1.1;CM-VER=3.1;
      Mon Mar 21 19:48:23 2022 (Warning (5)) MDD message timeout;CM-MAC=80:cc:9c:dd:37:d0;CMTS-MAC=00:01:5c:8d:18:58;CM-QOS=1.1;CM-VER=3.1;
      Mon Mar 21 19:48:23 2022 (Critical (3)) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=80:cc:9c:dd:37:d0;CMTS-MAC=00:01:5c:8d:18:58;CM-QOS=1.1;CM-VER=3.1;
      Mon Mar 21 19:47:42 2022 (Notice (6)) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=80:cc:9c:dd:37:d0;CMTS-MAC=00:01:5c:8d:18:58;CM-QOS=1.1;CM-VER=3.1;
      Mon Mar 21 19:47:37 2022 (Notice (6)) TLV-11 - unrecognized OID;CM-MAC=80:cc:9c:dd:37:d0;CMTS-MAC=00:01:5c:8d:18:58;CM-QOS=1.1;CM-VER=3.1;
      Mon Mar 21 19:43:18 2022 (Notice (6)) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=80:cc:9c:dd:37:d0;CMTS-MAC=00:01:5c:8d:18:58;CM-QOS=1.1;CM-VER=3.1;
      Mon Mar 21 19:43:13 2022 (Notice (6)) TLV-11 - unrecognized OID;CM-MAC=80:cc:9c:dd:37:d0;CMTS-MAC=00:01:5c:8d:18:58;CM-QOS=1.1;CM-VER=3.1;
      Mon Mar 21 19:27:41 2022 (Warning (5)) Dynamic Range Window violation
      Mon Mar 21 19:27:41 2022 (Warning (5)) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=80:cc:9c:dd:37:d0;CMTS-MAC=00:01:5c:8d:18:58;CM-QOS=1.1;CM-VER=3.1;
      • plemans's avatar
        tougher to read when you post them like that.
        Take a screen snip of them. Its easier to read/layout.
