Eich8891
Sep 05, 2021Aspirant
CM2000 LED and R8000
As it's probably been fairly established that the R8000 has a firmware issue with handling data packets. i.e. not reaching speeds past 300mbps in my particular case. I am now trying to figure out why ...
Sep 05, 2021Guru - Experienced User
FURRYe38 answered the 2.5g port versus the 1gig port.
in terms of the routers speed, you should be able to hit 800mbps when wired (won't hit that wireless).
1. what firmware version are you on?
2. have you used qos, access controls, traffic monitoring, or parental controls on your devcie? if so, factory reset it and reinstall it (not from a backup). during the install, make sure to leave those services disabled.
- Eich8891Sep 05, 2021AspirantYes thank you for answering the LED "issue." Rookie mistake, cannot believe I didn't even think about that. But now to the other issue:
1. Firmware 1.0.4.74
2. I had these disabled and did a factory reset last night. I left all of them disabled after the factory reset but it still was giving me speeds of 250-300mbps off LAN. I know it's not the cables as I got the speeds you would expect when I was directly connected to the CM2000.- plemansSep 05, 2021Guru - Experienced User
How are you testing lan speed?
what pc/laptop and what site?
Using ipv4 or ipv6? (shouldn't matter but stranger things have happened)
Try downgrading the firmware 1 version. Then after its reset, only set it up with the basics. don't change anything.
Test its speeds at that point.
If it hits full speeds, then start changing things 1 at a time and see if anything impacts the speeds.
- Eich8891Sep 05, 2021AspirantI'm testing off my desktop computer (That's the one that has 2.5Gbps port if I did just the modem to desktop). I just use the speedtest.net by ookla in conjunction with Xfinitys speed test but mostly ookla.
I believe it's ipv4.
I'll have to try going down to the 1st firmware version and see. So far the only "fix" is manually setting the QoS to 1000/1000 which QoS should be off for the speeds I'm supposed to get.
