Sallygood25
Sep 09, 2025Follower
CM2050V-speed capped at 50Mb download in a 500Mb plan
I installed this device in my house, put fiber directly on it, it registered without issues.
But I noticed a odd issue:
Any download is always capped at 50Mb/s (my plan is 500Mb/s for both downloads and uploads), but UPLOADS happen at full speed (500Mb/s).
I tried some troubleshooting but nothing seems to work!
I suspect it might have to do with firmware (I've updated it to latest firmware), but the problem is I can't find the original firmware that came with it
ISP told me this router is compatilble, and they advised me to contact Netgear, which I'm doing, because it might be a software fault on device's side.
It seems this is a secret device only ISPs have access.
I mean, come ou guys! This router is sold in many places, and we currently can buy it from stores and install it ourselves.
- DarrenMSr. NETGEAR Moderator
Here is a KB on what firmware is installed based on the ISP. https://kb.netgear.com/000036375/What-is-the-latest-firmware-version-of-my-NETGEAR-cable-modem-or-modem-router
Thanks
DarrenM
The CM series is a modem, not a router.
Which ISP is the modem connected with?
What FW is installed ON the modem?
What brand and model host wifi router is connected to the CM Modem?What speeds do you see if ethernet connected directly to the back of the CM modem with a ethernet connected PC?
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-routerSallygood25 wrote:
It seems this is a secret device only ISPs have access. - plemansGuru - Experienced User
Who's your ISP? I'm wondering if you have it backwards as xfinity's upload max for their next gen devices (which the cm2050v isn't sadly) is 300mbps (usually hits 350mbps). The max upload for the CM2050v is 40mbps. see here: https://assets.xfinity.com/assets/dotcom/projects/cix-4997_compatible-devices/2024.09.18%20Full%20List%20of%20Compatible%20Devices.pdf
So I'm wondering if you have it backwards.
- KitsapMaster
plemans, your list is out of date. Below is a screen snip from the Xfinity sub-forum over on Reddit.
