MojoGene's avatar
May 29, 2025
CM3000 Repeated Cox disconnects with SYNC Timing Synchronization failure
The CM3000, which I have owned for <30 days, is having repeated disconnection issues. Cox is my ISP. The disconnections occur randomly, but multiple times per day and always require a hard reboot. The Event Log shows many lines associated with each disconnect, but the "critical" error that prompts the disconnect appears to be the following:
SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=54:07:7d:c6:e4:28;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
This identical entry has occurred dozens of times.
Cox technicians have replaced all cable lines and connections to and from the modem out to the street. The last Cox service technician says that the modem is failing to maintain an upstream channel lock and that the problem is with the modem.
Additional information:
ChannelLock StatusModulationChannel IDFrequencyPowerSNRCorrectablesUncorrectables
1LockedQAM2565141000000 Hz7.9 dBmV45.6 dB00
2LockedQAM2561117000000 Hz7.6 dBmV45.2 dB00
3LockedQAM2562123000000 Hz7.9 dBmV45.6 dB00
4LockedQAM2563129000000 Hz7.9 dBmV45.6 dB00
5LockedQAM2564135000000 Hz8.0 dBmV45.8 dB00
6LockedQAM2566147000000 Hz7.8 dBmV45.9 dB00
7LockedQAM2567153000000 Hz7.7 dBmV45.9 dB00
8LockedQAM2568159000000 Hz7.7 dBmV45.9 dB00
9LockedQAM2569165000000 Hz7.6 dBmV45.9 dB00
10LockedQAM25610171000000 Hz7.6 dBmV46.0 dB00
11LockedQAM25611177000000 Hz7.5 dBmV45.9 dB00
12LockedQAM25612183000000 Hz7.7 dBmV46.0 dB00
13LockedQAM25613189000000 Hz7.7 dBmV46.0 dB00
14LockedQAM25614195000000 Hz7.8 dBmV44.5 dB00
15LockedQAM25615201000000 Hz7.8 dBmV45.1 dB00
16LockedQAM25616207000000 Hz7.8 dBmV45.3 dB00
17LockedQAM25617213000000 Hz7.9 dBmV46.0 dB00
18LockedQAM25618219000000 Hz7.8 dBmV46.1 dB00
19LockedQAM25619225000000 Hz7.7 dBmV46.2 dB00
20LockedQAM25620231000000 Hz7.7 dBmV46.3 dB00
21LockedQAM25621237000000 Hz7.5 dBmV46.3 dB00
22LockedQAM25622243000000 Hz7.5 dBmV46.3 dB00
23LockedQAM25623249000000 Hz7.4 dBmV46.3 dB00
24LockedQAM25624255000000 Hz7.4 dBmV46.0 dB00
25LockedQAM25625735000000 Hz6.0 dBmV44.1 dB00
26LockedQAM25626741000000 Hz6.0 dBmV44.0 dB00
27LockedQAM25627747000000 Hz5.9 dBmV43.9 dB00
28LockedQAM25628753000000 Hz6.2 dBmV43.9 dB00
29LockedQAM25629759000000 Hz6.1 dBmV43.8 dB00
30LockedQAM25630765000000 Hz6.0 dBmV43.8 dB00
31LockedQAM25631771000000 Hz5.9 dBmV43.7 dB00
32LockedQAM25632777000000 Hz5.7 dBmV43.6 dB00
Upstream Bonded Channels (Partial Service)
ChannelLock StatusUS Channel TypeChannel IDSymbol RateFrequencyPower
1LockedATDMA25120 Ksym/sec24000000 Hz34.5 dBmV
2LockedATDMA15120 Ksym/sec17600000 Hz34.0 dBmV
3LockedATDMA35120 Ksym/sec30400000 Hz34.5 dBmV
4LockedATDMA45120 Ksym/sec36800000 Hz35.0 dBmV
5Not LockedUnknown0000.0 dBmV
6Not LockedUnknown0000.0 dBmV
7Not LockedUnknown0000.0 dBmV
8Not LockedUnknown0000.0 dBmV
Downstream OFDM Channels
ChannelLock StatusProfile IDChannel IDFrequencyPowerSNR / MERActive Subcarrier
Number Range
Unerrored
Codewords
Correctable
Codewords
Uncorrectable
Codewords
1Locked0 ,1 ,2 ,3159300000000 Hz7.78 dBmV45.5 dB296 ~ 789582294164171648210
2Locked0 ,1 ,2 ,3160918000000 Hz7.18 dBmV43.4 dB2216 ~ 5975821676771106610534
Upstream OFDMA Channels
ChannelLock StatusModulation / Profile IDChannel IDFrequencyPower
1Not Locked11 ,13636800000 Hz31.0 dBmV
2Not Locked000 Hz0 dBmV
Advice, assistance would be much appreciated.
  • Thanks. I have the 500G service and typically experience downloads speeds in the 500-600G range with uploads 50-60G range. Plenty for what I do and no hiccups (for now).
    • iFrog's avatar
      iFrog
      Guide
      Gotcha, I had that while I was troubleshooting my connection being unstable on gigabit.  Works well, so yeah, the SB8200 will be fine for that if it stays stable.  Also the one before that ending in 90, I think 6190 is also certified for 500 with Cox and that's a 3.0 modem.  Either way, glad you got it sorted, and you can enjoy a stable connection again.
  • Same issue with my modem and cox, had 5 techs on site they replaced everything inside  and outside my home, made a FCC complaint with cox they replaced a bunch of stuff on the street as well as the hub and still having the same problems as so many other people (up stream not locking, constant disconnects, intermittent disconnects, and disconnects where nothing show up in the logs and everything shows good connection but have no internet)  i really wish i could have returned this modem at this point, i bought it back in may it worked for about 20 days and than the problem's started when they pushed this firmware. and here we all are with a 300$ piece of useless equipment. kind of crazy this has started 3 months ago and netgear hasn't really done anything to fix this.
    • FURRYe38's avatar
      All users having the CM3000 modem with v6 FW need to tell the ISP to roll back the FW to prior working FW. Only ISPs can effect this revert in FW. CC/XF has already rolled users back. Make contact with NG support in regards to let them know your situation. NG has already been working with most ISPs regarding this.
      Nothing further can be done here in the forums.
      Good Luck.
      • FURRYe38's avatar
        All this is on the ISP. Got word that the ISP has corrected this on there side. CM3000 modems should be good now. Please contact the ISP for continued help and information regarding this.
        Good Luck.
