Trekerj
Jun 15, 2018Aspirant
Cm400 not passing internet signal through to r6120 router
wasI am losing my inter net signal connection from my Cm400 modem when I connect to my R6120 router. If I directly connect my PC into the modem there is no issue, but when I put the wireless router in the mix, the LAN indicator on the modem trurns off and I have no internet signal passing to the router. I have tried several cables that I am sure work.
- DarrenMSr. NETGEAR Moderator
can you post your power levels of the modem to make sure its not a issue with the ISP connection.
DarrenM
- TrekerjAspirant
ive had the ISP check the connection into and back from the modem when I have a direct lan connection to the pc. The connection is good according to them, l'm not sure how to measure the power directly my self?
you would need to log into the modem by going to 192.168.100.1 login with admin/password and there you can access the power levels and screen shot it.
DarrenM
