Joepence's avatar
Joepence
Follower
Oct 05, 2022
cm500 how to switch to 2.4ghz
how can I get into settings to change network to 2.4ghz?  I have some lights that are wifi enabled and 2 of the 4 keep losing signal.  I thought maybe I could try to make sure they are on the right channel.
  • Click advanced setup then customize wifi network. In the customize your wifi- create a separate 2.4GHz wifi network section after that select customize 2.4 GHz wifi network. Enter a network name (SSID) for your 2.4GHz network.
  • plemans's avatar
    The CM500 is a modem only device. It has no wireless functions.
    so there isn't anything to change on it.
    What actual router do you have?
