Lefti3's avatar
Lefti3
CM500 keeps DC'ing
Hi,
I recently got Xfinity internet but the internet signal keeps disconnecting atleast couple of otimes everyday and at random times. The xfinity tech came here because my two cable inputs were not receiving the signal. He came and fixed the issue which was the wrong line in the cable box. Then it worked for a day but keeps dc'ing and it is super annoying. I bought this NETGEAR CM500 refurbished from amazon as "Like New". Not sure if it this modem or ISP screwing me over.
I have attached the logs from the modem.
  • Heres another log, since I cant add mutiple logs.
  • FURRYe38's avatar
    Be sure there are no coax cable line splitters in the between the modem and ISP service box.
    Be sure your using good quality RG6 coax cable up to the modem.
    Be sure to power OFF the modem for 1 minute them back ON.
    Ask the ISP to check the line and there logs when this happens to see if they notice the same time.
    I would try another modem as well, sometimes refurbishes items can be problematic.
    • robturpin's avatar
      robturpin
      Apprentice
      Hi,  I purchased my CM500 brand new from Amazon about 6 months ago, and it's doing the exact same thing!  This is ridiculous.  It will simply drop the connection, and then regardless of whether I call Comcast or not, it starts working again within about 5-10 minutes.  It did it both yesterday and tonight, and so I called Camcast and after waiting on hold for over an hour, I was told by the person that my modem shows that it's offline.  She further said that their attepmts to re-provision it keep failing, and that the error is coming from my device - NOT their service.  I don't care who or what the issue is, but it's wuite strange that SEVERAL people are having the EXACT same issue using this particular modem with COMCAST service.  Can someone please help us figure out exactly what is going on here?  I can't pay for anyone to come out and "check" or service my cable lines, as I'm currently unemployed and only kept internet to look for work.  Thank you!!
      • FURRYe38's avatar
  • FURRYe38's avatar
    Any progress on this?
    Lefti3 wrote:
    Hi,
