labasedlife's avatar
labasedlife
CM500 Modem drops internet connection , then reconnects eventually
The attachments are from the other day when it dropped last
      • plemans's avatar
        check your line for signal attenuators, splitters, amplifiers.
        Remove them if you do.
        Also, check the cable for kinks, damage, poor/old/loose/corroded connectors.
        You have errors in your line and the logs having connection errors.
