ragerDuane's avatar
Jan 23, 2021
CM500 Modem keeps dropping internet, then reconnecting eventually
I used to use my CM500 modem with R6700v3 router with Vyve Broadband at my old address. I never had any significant internet issues. I moved to a new location and got service with Sparklight. Everything was fine for the first 3 days. On the 4th day, my internet just started dropping for several minutes, and then reconnecting. This has gone intermittently all day. This happened simulataneously with wifi and ethernet. I later plugged my computer in directly to my router and the issue continued, confirming that it is not the router or anything wired after the modem. I physically checked all wires from the wall out and found no loose connections or damaged wires. I also tried resetting the modem, my router, and computer. I tried a full power cycle, too.
I called Sparklight. They saw live, the same time as me, when my modem would disconnect and then eventually reconnect. They supposedly didn't see anything on their side that could resolve the issue. They are sending a technician to come look at the lines outside, but already warned me that if they find nothing they are going to ask me a to use their modem. If I decline that, they will tell me to get a new modem. I don't think I need a new modem. It worked perfectly with my last ISP, and it is barely 1 year old. They, of course, did not even ask about my modem's reported cable connection or event log. I am skeptical that the technician will either.
The one thing on my end that I can think of that POSSIBLY is the issue, is that I moved my desk a couple days ago and when I put it back I pushed it up against the coax cable. But it has been like that for a couple days and the issue just started today. I don't think it was hard enough to crush or bend it. Also, I pulled the desk away, and upon visual inspection, there does not seem to be any physical abnormality. I will switch that cord out before trying a new modem, but in case that is not it, I still want to be prepared to face the ISP when they blame my modem.
I will post my cable connections and event log, as well as another event log right after a power cycle.
What do you guys think the issue is?
  • plemans's avatar
    Jan 25, 2021
    Check you line for amplifiers, attenuators, or splitters. remove them if you have them. check the line for damage, kinks, cheap/old/bad/loose connectors.
    Reason is your power levels are out of spec. They're to low and they should only be 3.5dbmv from each other. You're going from -11.2 dbmv (with errors) to -0.1dbmv.  so 11.1dbmv difference. couple that with the logs and theres issues with the line.
    if you checking your side of things doesnt help, then the isp needs to check that.
  • FURRYe38's avatar
    Please post a copy and paste of the modems connection status page.
    Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
    Be sure there are no coax cable line splitters in the between the modem and ISP service box.
    Be sure your using good quality RG6 coax cable up to the modem.
    Be sure to power OFF the modem for 1 minute them back ON.
    https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
    • ragerDuane's avatar
      ragerDuane
      Guide
      I couldn't get a legible copy and paste, so a pdf of the connections is attached above.
      • plemans's avatar
