dustinmartin23
Nov 27, 2016Follower
CM500 router and Nighthawk D700 (combo - how to disable the modem)
Hi All, I'm a bit new to this level of network config. Background: I have Cable and purchased a stand-alone CM500 Netgear modem and the Nighthawk D700 (modem + router). It worked prior to blo...
DarrenM
Nov 29, 2016Sr. NETGEAR Moderator
Hello Dustinmartin23
Have you tried to factory reset the D7000? You should leave the D7000 set to modem+router.
DarrenM
