AxleTheRed
Mar 09, 2017Tutor
CM600 Status page 192.168.100.1 does not work on any of my computers. Works on cell.
First off, I can load the status page fine on my cell phone. Everything works right on it. However, it looks like none of the browsers on any computer I have tried supports it correctly. I can login to it but it is messed up. It looks like this: http://imgur.com/a/7NNao
When I load it on my phone it says firmware version is V1.01.12. My ISP is Comcast.
I can access the cable modem status on my computer, these are results:
Cable Connection Frequency start Value This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. Starting Frequency Startup Procedure Procedure Status Comment Acquire Downstream Channel 621000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Security Enable BPI+ IP Provisioning Mode Honor MDD IPv6 only Downstream Bonded Channels Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked QAM256 11 621000000 Hz -1.6 dBmV 39.5 dB 0 0 2 Locked QAM256 1 561000000 Hz -1.6 dBmV 39.5 dB 0 0 3 Locked QAM256 2 567000000 Hz -1.6 dBmV 39.7 dB 0 0 4 Locked QAM256 3 573000000 Hz -1.7 dBmV 39.6 dB 0 0 5 Locked QAM256 4 579000000 Hz -1.6 dBmV 39.7 dB 0 0 6 Locked QAM256 5 585000000 Hz -1.8 dBmV 39.6 dB 0 0 7 Locked QAM256 6 591000000 Hz -1.7 dBmV 39.5 dB 0 0 8 Locked QAM256 7 597000000 Hz -1.6 dBmV 39.6 dB 0 0 9 Locked QAM256 8 603000000 Hz -1.7 dBmV 39.5 dB 0 0 10 Locked QAM256 9 609000000 Hz -1.7 dBmV 39.4 dB 0 0 11 Locked QAM256 10 615000000 Hz -1.5 dBmV 39.5 dB 0 0 12 Locked QAM256 12 627000000 Hz -1.4 dBmV 39.5 dB 0 0 13 Locked QAM256 13 633000000 Hz -1.3 dBmV 39.4 dB 0 0 14 Locked QAM256 14 639000000 Hz -1.1 dBmV 39.5 dB 0 0 15 Locked QAM256 15 645000000 Hz -0.9 dBmV 39.6 dB 0 0 16 Locked QAM256 16 651000000 Hz -1.0 dBmV 39.5 dB 0 0 17 Locked QAM256 17 657000000 Hz -1.2 dBmV 39.4 dB 0 0 18 Locked QAM256 18 663000000 Hz -1.3 dBmV 39.4 dB 0 0 19 Locked QAM256 19 669000000 Hz -1.6 dBmV 39.0 dB 0 0 20 Locked QAM256 20 675000000 Hz -1.7 dBmV 38.9 dB 0 0 21 Locked QAM256 21 681000000 Hz -2.3 dBmV 38.6 dB 0 0 22 Locked QAM256 22 687000000 Hz -2.5 dBmV 38.6 dB 0 0 23 Locked QAM256 23 693000000 Hz -2.8 dBmV 38.2 dB 0 0 24 Locked QAM256 24 699000000 Hz -3.1 dBmV 37.8 dB 0 0 Upstream Bonded Channels Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 10 5120 Ksym/sec 23700000 Hz 42.0 dBmV 2 Locked ATDMA 11 5120 Ksym/sec 30100000 Hz 41.8 dBmV 3 Locked ATDMA 12 5120 Ksym/sec 36500000 Hz 43.0 dBmV 4 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 5 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 6 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 7 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 8 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV Current System Time: Thu Mar 09 14:42:13 2017 Help Center Show/Hide Help Center
edit: I had previously used a rented gateway, I think it is trying to load the page for that perhaps? I don't know.
I found the solution. I use Kaspersky internet security on all of my computers. If I disable kaspersky, everything loads and displays properly.
edit: to resolve without disabling kaspersky entirely, right click on settings, additional, network, then disable "traffic processing: inject script into web traffic to interact with web pages"
Doing this will disable safe money and a few other plugins, but the modem status page will work correctly.
This issue has been fixed in the latest update of Kaspersky, released March 13 2017.
See https://forum.kaspersky.com/index.php?showtopic=366979
and https://forum.kaspersky.com/index.php?showtopic=361588
It also fixed an issue I had logging in to 192.168.1.1 on my computer with kaspersky.
