evett5's avatar
evett5
CM600
I got a new cm600, The problem is the modem will not display Cable connection or Event Log. When I do a factory reset it will display cable connection and event log for a little while then disappears.
  • plemans's avatar
    Is it powering up and attempting to connect to your provider?
    What are you led lights on the front doing? (describe what each light is doing, color, blinking/steady)
    Have you had it/are you able to get it provisioned from your provider?
