obiorbi
Jun 19, 2025Follower
connect CBR750 to xfinity gateway without ethernet cable?
Apparently xfinity isnt charging equipment rental fees anymore. I was trying to make a small adjustment to my internet plan and the rep said it was cheaper for me to use their xfinity gateway rather ...
Jun 19, 2025Guru - Experienced User
the CBR requires the ISP coax cable to be connected to work correctly.
Yes you can configure the CBR for a faux AP mode using the LAN port to connect it to a host router LAN port. Need to set the CBR to the same subnet IP address as the host router, then disable the DHCP server on the CBR.
