obiorbi
Jun 19, 2025Follower
connect CBR750 to xfinity gateway without ethernet cable?
Apparently xfinity isnt charging equipment rental fees anymore. I was trying to make a small adjustment to my internet plan and the rep said it was cheaper for me to use their xfinity gateway rather ...
HappyCat
Jun 19, 2025Virtuoso
obiorbi wrote:Having the gateway and CBR right next to each other seems like a waste of wifi coverage
Most of us would prefer to have a single WiFi network covering the entire house than two WiFi networks. If there are satellites in addition to the CBR750, that would be a mesh WiFi system which will cover more of the building than a single WiFi node (the Xfinity gateway).
If the house is large enough to require more than one WiFi access point, most people would pick the Orbi or Xfinity, but not both.
obiorbi wrote:rep said it was cheaper for me to use their xfinity gateway
The CBR750 is designed to connect to Cable Coax. Is the Xfinity gateway also a Cable modem? (not fiber?) Maybe Xfinity no longer charges for equipment (really???) I struggle to understand how the monthly cost of service would be less when they provide equipment than when they do not.
- FURRYe38Jun 21, 2025Guru - Experienced User
One can use a CBR in faux AP mode and if there is a satellite, still use the system in AP mode with the ISP router, as long as they turn the ISP modem wifi OFF. The CBR system still can be used as a MESH system with there ISP router.
