pghkatrina's avatar
pghkatrina
Connecting router to external USB drive
I'm trying to add my external USB HD to the router and am running into a few problems:
1) I don't know if I can use it to backup via Time Machine or only for additional storage? I followed the Time Machine guide to partition the USB drive. I'd like to be able to store backups on it. Is this possible?
2) I attached the USB drive to my router and reach the point to connect to server and keep getting an error that my MacBook cannot connect. I opened Genie and everything is good, so I'm unsure as to what the problem is.
MacBook Pro Late 2011
macOS High Sierra 10.13
Just updated Genie to 2.4.26
Any help appreciated. Thanks.
  • > 1) I don't know if I can use it to backup via Time Machine or only for
    > additional storage?
       What's the difference?  Time Machine backup files are only files.
       Which "the Time Machine guide" was that?  How, exactly, did you
    "partition the USB drive"?
       The existence of "the Time Machine guide" would suggest that.  Given
    the number of complaints in these forums and my own (very limited)
    experience, I wouldn't trust it until I'd tested it myself.
    > connect.
       Are you talking about using the Finder's Go > Connect to Server...?
    If so, then what did you do with it?  Browse?  Specify something like
    "afp://readyshare" or "smb://readyshare"?  Or System Preferences > Time
    Machine > select Disk...?  Or what?  Did you provide any name and
    password credentials when requested?  What was the actual error message?
    > I opened Genie and everything is good, [...]
       Ever helpful, Netgear uses the name "Genie" for more than one thing.
    I'll assume that you're using the web interface, not some application
    program.
       Define "everything".  Define "good".  As usual, showing actual
    actions with their actual results (error messages, ...) can be more
    helpful than vague descriptions or interpretations.
    • pghkatrina's avatar
      pghkatrina
      1) There is a big difference:  if I can connect the USB to the C6300 and run Time Machine backups to it wirelessly or if that isn't possible and I'm only able to store media files.
      2) The issues you refer to (complaints, etc) is why I'm asking the question. This guide: Time Machine Setup for Routers I what I used to partition. Yet it refused to connect at the point of "Connect to Server" in the instructions in previously mentioned guide... which does include the steps you mentioned.
      4) I referred to my MacBook so I thought that would be clear enough as to where I was using Genie... Guess not.  And GOOD was what the app said in STATUS.  See screenshot.
      • antinode's avatar
        antinode
        Guru
        > 1) There is a big difference: [...]
           Not really.  Files are files.  Network access is network access (give
        or take).
        > [...] This guide: [...]
           As I read that, you have some USB-connected disk or other with a
        normal Mac OS Extended (Journaled) partition.  While it was connected to
        the Mac, did you copy some files to it, and verify that you could
        recover them?
           What, exactly, does "refused to connect" mean?  Did you get any
        actual error message(s)?
           Which "the steps"?  I mentioned many possible steps.  I assume that
        you didn't try all of them.
        > [...] Did you provide any name and password credentials when
        > requested?  [...]
           Still wondering.
           The question was not where, but what.  Netgear routers have a
        web-browser interface called "Genie", and Netgear offers application
        programs for various computers/pads/phones, which are also called
        "Genie".  Are you using a web browser or one of the apps?  (Which?)
           That shows that your "Internet" status is good, which means that
        you're connected to the Internet.  It says little or nothing about your
        ReadySHARE storage.
        > [...]  As usual, showing actual
           Still true.  When your audience comprises non-psychics, things which
        you can see easily may remain obscure to your audience.  Unless, of
        course, you reveal what you're actually doing, and what actually happens
        when you do it.
