sciasciaale
Feb 07, 2016Aspirant
DGND4000 - 1TB hard disk NTFS problems with DLNA
Hi, i have an strange problem with my router.
My router doesn't support my hard drive 1TB NTFS, all users in wifi or cable will disconnect or go to wifi error when i'll allow DLNA service ( multimedia server) or when i turn on that hard drive.
There is an suggestion to solve this issue? it's probably due that this router did not support 1TB?
many thanks,
- DarrenMSr. NETGEAR Moderator
Hello sciasciaale
Have you tried another hard drive or usb storage device to see if you are getting the same result as your Hard drive.
DarrenM
- sciasciaaleAspirant
Hi, thanks a lot for your reply, i tried with other disk, like 160 GB in to NTFS, there is no problem, but i absolutely need to use my 1TB hard drive.
Probably i will solve this issue buying an NAS.others suggestions?
Many thanks,Alessandro.
