khordas
Feb 17, 2017Initiate
Does the NETGEAR - AC1750 Dual-Band Router with DOCSIS 3.0 Cable Modem - Multi work with hughesnet
I need help Best buy sold me the NETGEAR - AC1750 Dual-Band Router with DOCSIS 3.0 Cable Modem - Multi for my hughesnet serivice. Both netgear and hughesnet are making me go back and forth between th...
PurpleCalico
Feb 18, 2017Tutor
While it should physically work since they connect via coax cable, whether or not they allow you to bring your own modem is a policy question. TWC/Spectrum has a list of approved modems on their site. If Hughes does not, you will need to contact them to ask their policy. Good luck
khordas
Feb 19, 2017Initiate
Thanks for the help but I finally was giving the correct answer from a zest buy rep online and it will not work with hughesnet. I have to get a modem only. The problem I have is I bought it in September and due to some serious family health issues I am just getting back to it now. So it is past the return date and also I live 3 hours from the store I bought it from.
