wifi99's avatar
wifi99
DOS Attacks - Cause Router to Reset
My modem/router(firmware version is V2.02.08 and model is N600(C3700-100NAS)) randomly resets when it gets pinged with various DOS attacks like
'DoS attack: Ping Of Death'
'DoS attack: Teardrop or derivative'
'DoS attack: Illegal Fragments'
I see these in the log in the 'Netgear Genie' (admin console site) and these dos attack occurrences usually show a 'count' of 1 or at most 4.
The source and target ip addresses are always non-US ip addresses with various ports.
What can I do to stop the resets or prevent these dos attacks from happening?
  • You should enable DoS attack blocking from your router firewall.
    • wifi99's avatar
      wifi99
      Ok, I've unchecked the 'Disable Port Scan and DoS Protection' box on the setup page.  Factory settings defaulted this to being checked - why?
      • wifi99's avatar
        wifi99
        After unchecking 'Disable Port Scan and DoS Protection', I'm now I'm seeing this in the logs 'DoS attack: TCP- or UDP-based Port Scan'.  Again the source and target ip addresses are non-US various countries.
        It hasn't caused a reboot yet but what is this?  My ISP is Time Warner.
