dayofsunshine
Feb 19, 2016Aspirant
Dynamic QoS with 2 routers?
Hi - I have a C6300 (combo modem and router) which has been delivering excellent speeds via Infinity Comast (though it does drop internet frequently). But I need to set up dynamic QoS to improve call...
netwrks
Feb 19, 2016Master
If you can log into the C6300 and edit it, you should be able to turn off router mode (this will turn it into a modem only) on the C6300 (that's if your ISP hasn't greyed out the feature to prevent you from changing the mode). If you can, then you can use your R7000, in router mode.
Manual: http://www.downloads.netgear.com/files/GDC/C6300/C6300_UM_17Nov2015.pdf - Starting at Page 71. If you can't change it, see if your ISP will do it for you.
- dayofsunshineFeb 19, 2016Aspirant
Ahhh - just brilliant! I will try this - thank you so much :)
