dvw1957
Jan 07, 2017Follower
Effect of replacing modem/router on an existing extender
My current modem/router is the C3700 Docsis 2.0. I just got off the phone with Comcast, and they informed me that I need to upgrade the modem to Docsis 3.0. I'm considering purchasing the C6300. Howe...
DarrenM
Jan 09, 2017Sr. NETGEAR Moderator
Hello dvw1957
Its pretty simple when you get a new modem you will want to factory reset the extender by holding the reset button for 10 seconds then you will be able to do a new setup of the extender and connect it to the new modem.
DarrenM
