sanchep2's avatar
sanchep2
FAST LAN speed / slow WiFi speed
I have register my cable modem with xfinity and i do have internet access
when i connect to the 5g Wifi I get at most 54Mbps but when connected via ethernet to the netgear box i get the 75+ Mbps
here are my Wifi settings
and my internet speed results via http://www.speedtest.net/
and here are the same results via ethernet
  • I just did a test, i connected an Independent Access point
    when connected to my Access Point (myAP)  I get the following Internet Speed
    when i connect to the NetGear
    • DarrenM's avatar
      DarrenM
      Sr. NETGEAR Moderator
      Hello sancep2
      Have you tried to change the wireless channel Also I have seen if you change the modem to a lower speed it can fix some wifi speed issues.
      DarrenM
      • sanchep2's avatar
        sanchep2
        on 2.4 GHZ i have tested 3 6 and 11
        and on  5Ghz i have used the empty one
        i am starting to think that the box is busted
