Kakashi2000
Sep 14, 2016Star
fix the sistem log for modem and router and ect
fix the sistem log so if some one hack the modem so can delete the modem log fix that make a encription or password for logs
fix firewall input lag playing games /make a turbo firewall to play for gaming
fix securty slow down the network speed playing online and feel slow playing games with all security enable make something to make that super fast that dont affect gaming and dont create input lag on games
fix firewall dont log attack or ect when dos and portscan is disable
fix upnp get glish and sometimes dont detect devices correcly or ports
make a new upnp that open port for gaming automatic or manual and that you can remove all device or uknow ip connected to upnp
fix 5G wirless dont have auto chanels
make that Lan have a encription so to be protected with Https or higther security level
fix modem login is vulnerable stop using http and use highter security login like hhtps or a new higter level security login why some haker try to hack the modem but he was unable to enter so fix that put all user to risk
make a new hide my ip or ghost ip so you can protect from hakers and spy or ect that whant to attack you so you can be protected
make a new AI protection that kill all bad trafics and hakers and uknow programs that whan to attack you or disconect you from online from xbox or anything
make a new nat extreme aceleration for gaming and lan extreme aceleration for online gaming and super fast reponce for online gaming and extreme ping reduction
make a new software desing for the new modem and raouter that look super hd and super moderm
fix firewall and dos protection i been notice with simple attack the modem some times reset itself fix that mean have a weak dos proctection
make a new protection that any attack crash the pc
make new (AI anti exploit mitigation).... and process protection and network, and software ,and cpu and memory ,and hardware
make a new radar that show the atack locations like a maps ect
fix scrips vulneravility a haker cold bypass it why scrips always been vulnerable and contain alot of error fix that and make and anti exploit for this too
use military grade security or higther
make a strong defend for any virus and any attack
just helping
1 Reply
fix raouter and modem netowrk drops for lan and wirless and ect on any settings to
