iamawb
Apr 12, 2017Tutor
Frequency start Value
Hello, I have the CM1000 Firmware V2.01.15 cable modem and so far its been great. I am curious as to why channel 32 is getting 30,000+ uncorrectables and around 4-5000 correctables. I changed the Fre...
- Apr 14, 2017
Hello iamawb
Yea if you start seeing disconnects I would contact the ISP
DarrenM
DarrenM
Apr 14, 2017Sr. NETGEAR Moderator
Hello iamawb
That is nothing to worry about unless you are seeing really large numbers then there is a issue with your connection.
DarrenM
iamawb
Apr 14, 2017Tutor
Large like these numbers?
- DarrenMApr 14, 2017Sr. NETGEAR Moderator
Hello iamawb
DarrenM
- iamawbApr 14, 2017Tutor
Thank you for the info. So far no disconnects what so ever and my speeds are always 350-380 no matter what time of day when I check/test it. Made me wonder if it could be a bug or something and just need to wait on another firmware update to fix it idk.
