Prim's avatar
Prim
Fs608 v2 - 8 Ports: How to connect to DsL Modem
Hello,
I've got a FS608 v2 Fast ethernet swicth from my friend. But i don't know how to connect this
to the DSL Modem. Which Port do i use for the ethernet cable that comes from the DSL moden.  Normaly you would connect this in the WAN port. But i Have now 8 ports.
Which port i use to connect to the Modem.
Thanks in advanced.
  • > [...] i don't know how to connect this to the DSL Modem. [...]
       What, exactly, is your "the DSL Modem"?  If it's a modem+router, then
    you should connect (any) one of its LAN Ethernet ports to any port on
    the switch.  (And other gizmos to other ports on the switch.)
    > [...] FS608 v2 Fast ethernet swicth [...]
       Note that "Fast Ethernet" is now a misnomer.  Gigabit Ethernet is now
    pretty common.  If your other equipment is gigabit-capable, then adding
    a "Fast" (10/100MHz) switch to a gigabit (1000MHz) environment could add
    a new bottleneck.
    > [...] from my friend.
       Cultivate friends with better junk?  An 8-port gigabit switch can be
    pretty cheap these days.
    • Prim's avatar
      Prim
      The modem is just a modem. Not a modem + Router
      • Prim's avatar
        Prim
        I have connected the DSL Modem to a 4 ports switch from a different manufacturer. The cable from the modem is connected to the WAN port of the switch now. But i Can't find a WAN port of the FS608 switch. I see only LAn ports.
