Retired_Member's avatar
Retired_Member
Jan 10, 2019
Gigabit ports
Instructions are vague to me.  Can I plug a laptop with an ethernet cable into LAN1 and set my network router up by plugging it into LAN2 with no adverse effects of speeds?  Or can I ONLY connect an ethernet cable betweeen the router and the modem and then HAVE TO plug the laptop into the router?  The instructions make it sound that way to me.
Thanks in advance for your help.
  • > Instructions are vague to me. [...]
       They _can't_ be any worse than your problem description.
    > [...] Can I plug a laptop with an ethernet cable into LAN1 and set my
    > speeds? [...]
       Who could possibly know?  What is your "a laptop"?  What is your "my
    network router"?  What is your "the modem"?  Who is your ISP?  "LAN1" on
    what?  "LAN2" on what?  What are you trying to do?
    > [...] The instructions make it sound that way to me.
       Which "The instructions"?
       Assuming that some Netgear router (or other device) is involved
    somehow, visit http://netgear.com/support , put in your (actual) model
    number, and look for Documentation.  Get the User Manual.  Read.
       If questions remain, then return with some useful information about
    your equipment, your intent, your actions, their results, and so on,
    targeted at non-psychics who can't see what you have, what you're doing,
    or what happens when you do it.
  • vkdelta's avatar
    vkdelta
    NETGEAR Employee Retired
    Your ISP will ONLY give you one Public IP unless you have signed up for multiple IP service which Most ISPs do not. Please only connect one device to one LAN port.
    you can use 2 LAN ports for one device if you setup LAG with a LAG capable router.
    • Retired_Member's avatar
      Retired_Member
      Thanks, that is a great explanation.
      Jerry
