Panda337
Aug 07, 2017Follower
Good matched Router for CM1000?
Trying to setup a network with a CM1000 on Xfinity. I live in a 1930 House with plaster walls so Wifi barely bleeds from room to room. I ran CAT6 from basement to attic patch panel thendrops into eac...
Mac58
Aug 12, 2017Aspirant
I just purchased the cm1000 also. Paired it with linksys velop w/2 nodes. Don't waste your time with that, I can assure you. I'm taking it back. ...I'm interested to learn what works with this modem.
Mac58
Aug 24, 2017Aspirant
After some additional research and experimenting, I've come to the conclusion that the Velop nodes have to physically "see" each other in order to provide optimum performance. Not having issues now, system is doing fine. Two story, 3300 sq ft house. Any more than that you may want to consider the three node Velop system.
