Panda337
Aug 07, 2017Follower
Good matched Router for CM1000?
Trying to setup a network with a CM1000 on Xfinity. I live in a 1930 House with plaster walls so Wifi barely bleeds from room to room. I ran CAT6 from basement to attic patch panel thendrops into eac...
Switchless
Jan 13, 2018Aspirant
Panda - It is interesting that you connected the CM1000 to your AC1200 router first. I purchased the CM1000 and connected to the GS108 switch and while all 8 LAN ports Light up, only one connection works out of the switch. I have another Lynksis E2800 switch which I also tried with the same results. I have some routers that actually do work an old Netgear RP614v2 and a Lynksis E4200. Both routers work and extend my LAN but the location of the wireless router near the modem gives low coverage in my house. My conclusion is that the CM1000 isn't compatible with switches (at least two that I have tried). Netgear tech support has been useless. Has anyone else seen this or perhaps my CM1000 is defective...?
