RL9257's avatar
RL9257
GS108v4 replace power adapter
I need to replace a power adapter for my NETGEAR ProSAFE GS108 8-Port Gigabit Desktop Switch (GS108-400NAS). My cat ate the cord :-(. I am seeing model number as AD2015F23 but cannot find that part anywhere. Does anyone know which adapter I can order?
  • According to this datasheet, the GS108v4 requires a 12V adapter capable of at least 0.5A.  If you don't mind getting a 3rd party replacement, just go on Amazon and search for gs108 adapter and you can find any number of options.  Or go to a retail store, like Walmart, Target, Best Buy, etc. and look for a generic 12V AC/DC adapter that can supply at least 0.5A.  Take your broken adapter and make sure to find an adapter with the same connector and polarity (tip +, ring -).
  • Which cord? Input side or outpust ide? If it is just damaged, you can repair the damage, most likely by splicing two wires. If it is output side ,
    make sure splice the wires exactly identical one. Being DC it is polarized. Usually one wire has a white strip or rib which is (-) side. Or if
    you want a replacement  one with same or better specs will do. Just  make sure the polarity of the output conenecter. Netgear does not
    make adapters, Amazon or eBy will have plenty of choices. I bet you could even find a exact replacement.
