rareaagle's avatar
rareaagle
have to reset modem a lot
Have to reset modem a lot. Modem problem or ISP problem?
  • michaelkenward's avatar
    michaelkenward
    What prompts you to reset the modem?
    And what do you mean by "reset"? On/off or (pin in the back) factory reset?
    • rareaagle's avatar
      rareaagle
      Unplug power, wait couple minutes, and plug it back it. This will correct problem (no internet)
        michaelkenward
        Sorry, but another question, when you say "no internet", do you mean that the wifi goes off, or stuff wired to the router?
        What do the lights on the thing look like when this happens?
        There is support for the CM400 at the end of this link:
        >>> CM400 | Product | Support | NETGEAR<<<
        Check the section Use LEDs to Troubleshoot.
