Homeboy123456's avatar
Feb 18, 2020
Having DNS connection issues on my guest Network - CG3000D
Hello,
I have set up a guest network on my Netgear cable modem.
The guest network is having trouble with DNS servers.
Some sites work fine: gmail, google, wikipedia.
Some sites give this error: hulu.com, netflix, my bank.
This site can’t be reached
www.hulu.com’s server IP address could not be found.
  • Try running Windows Network Diagnostics.
DNS_PROBE_FINISHED_NXDOMAIN
Network Diagnostics is no help.
One thing I noticed was the guest network does not have any IPV4 information. Not sure if that is relevant.
Things i have tried:
  • I have power cycled the modem.
  • I have removed the power cord and then restarted it.
  • I have tried to set the DNS manually for that network to 8.8.8.8 and 8.8.4.4 but when I would validate, it would take me to the Windows Network Diagnostics (WND). The WND would run for a bit then return that there wasn't an issue. But the issue persisted.
  • When I log into the modem, there doesn't seem to be any way to look at my 2nd network and adjust its settings.
  • Finally, the properties of my 2nd network doesn't include any IPv4 information.
Thanks in advance for any ideas.
Chris
  • plemans's avatar
    the CG3000D was a modem that was directly sold to ISP's such as cox/spectrum.
    https://kb.netgear.com/24324/No-NETGEAR-support-for-the-CG3000D
    I couldn't find much info on it or its newer version the CG3000D supporting a guest mode either. Potentially you could try factory resetting it but I doubt your isp is going to do much for support on it if it doesn't work.
    • Homeboy123456's avatar
      Homeboy123456
      Yup, that's exactly what happened. To the extent that they said they didn't work on 3rd party modems. I told them they provided me the modem!
      And yes, I read the manual for similar CG3000s, and there's NOTHING in there about guest networks. And yet, I created one via the Cox website; and I can discover it using my phone or computer.
      • plemans's avatar
        I would probably factory reset it to disable the guest network.
        I'm not a huge fan of guest networks. Those I trust on my network can use the full network, those who i don't, can use their phone date.
        Just what I've done on mine. No complaints yet
