brianthered
May 25, 2016Aspirant
Having trouble connecting an Xbox One to the Cable Modem Router C3700 - N600
I can connect the Xbox One through a wireless network with the router. The issue arrises when I try to connect the Xbox One to a ethernet cable from the back of the router (it needs to be wired becau...
VE6CGX
May 25, 2016Master
Tried different cable? You move Xbox closer to router and try another known good shorter
cable.
brianthered
That did not help, but I definitely appreciate you trying. At this point I'm willing to try anything.
- VE6CGXMay 25, 2016Master
If you have Widnows OS download a freeware utility called 'ipscan' Whe you run it it shows all the conneced devices(wired, wireless) and it's ip address. I am not a gamer, old retired. Xbox ought to have a NIC for wired connection. Is the NIC in ready status with latest driver?
- briantheredMay 25, 2016Aspirant
It says it is.
Wonder if it has ip address conflict. I notice many Youtube help is out there. Also power cycled router and modem?
