brianthered
May 25, 2016Aspirant
Having trouble connecting an Xbox One to the Cable Modem Router C3700 - N600
I can connect the Xbox One through a wireless network with the router. The issue arrises when I try to connect the Xbox One to a ethernet cable from the back of the router (it needs to be wired becau...
brianthered
That did not help, but I definitely appreciate you trying. At this point I'm willing to try anything.
VE6CGX
May 25, 2016Master
If you have Widnows OS download a freeware utility called 'ipscan' Whe you run it it shows all the conneced devices(wired, wireless) and it's ip address. I am not a gamer, old retired. Xbox ought to have a NIC for wired connection. Is the NIC in ready status with latest driver?
- briantheredMay 25, 2016Aspirant
It says it is.
- VE6CGXMay 25, 2016Master
Wonder if it has ip address conflict. I notice many Youtube help is out there. Also power cycled router and modem?
