LSUfan71
Mar 28, 2016Aspirant
How do I disable NETGEAR Genie from starting?
When I first used my cable modem and went to http://192.168.01 I arrived at a bare-bones setup (no web-based Genie). Then I downloaded/installed Genie. After a few days I decided I wanted to return...
- Apr 04, 2016
Hello LSUfan71
Unfortunately you can not revert back with a cable modem all the Firmware is pushed out by the ISP so that is why this happened so the new firmware updated everything.
DarrenM
netwrks
Mar 28, 2016Master
Uninstall genie from your laptop / desktop. Then launch a browser and connect to the IP address of the router. Genie is part of the router Web-UI. The imprtant part is not running it on a laptop / desktop..
- LSUfan71Mar 28, 2016Aspirant
I've installed and uninstalled Genie twice. I've deleted internet history/cookies from both IE and Chrome. Then connected both to the IP address of the router and the web-based Genei still appears.
Just now I deleted IE internet history/cookies (everything, again, and reset to default), reset router (2nd time today), uninstalled network adapter driver, and uninstalled network adapter from Device Manager. Then shut down my system and router for 10 minutes. Restarted. Used IE to go to http://192.168.0.1 and the web-based NETGEAR Genie started again.
Can't get rid of it. Please help.
- netwrksMar 28, 2016Master
You aren't reading what I typed. Genie is part of the Web-UI
As an example Only: Note that it is the Web-UI, in the firmware. Netgear WEB-UI example
