LSUfan71
Mar 28, 2016Aspirant
How do I disable NETGEAR Genie from starting?
When I first used my cable modem and went to http://192.168.01 I arrived at a bare-bones setup (no web-based Genie). Then I downloaded/installed Genie. After a few days I decided I wanted to return...
- Apr 04, 2016
Hello LSUfan71
Unfortunately you can not revert back with a cable modem all the Firmware is pushed out by the ISP so that is why this happened so the new firmware updated everything.
DarrenM
LSUfan71
Apr 04, 2016Aspirant
I was afraid of that. Thanks for the reply.
