DanteYoda
Jul 27, 2019Aspirant
How do i fix this?
Hello i'm having issues with my Antivirus its saying my Netgear D6220 is insecure on HTTP how do i go about fixing this i've checked through the settings and i cannot find a way to fix it..
Is it even possible without an update? I've not seen any updates in about 3 months since i purchased it.
Firmware Version
V1.0.0.52_1.0.52I see all i'll get here is condecending attitude.. Thats fine i understand you believe this to be nothing but i for one do not.. And i'm glad useless idiots like you are here to be smart asses to customers.
Netgear lost a customer today forever thanks to a scumbag with no training.. Good luck i hope this company fails i will tell whoever i can never to buy this trash.
Good luck good bye.
> [...] how do i go about fixing this [...]
You don't. You could ignore it.
> Is it even possible without an update? [...]
Probably not. "an update" from what?
- DanteYodaAspirant
antinode wrote:> [...] how do i go about fixing this [...]
https://community.netgear.com/t5/x/x/m-p/1726206
Ignore a potantial exploit into my system seems not smart and there has been no firmware updates for my modem since i purchased it.. i'm using the latest..
Its ok this will be the last netgear i ever buy, the software is poor and the support is non existent.. Obviously netgear takes security very lightly, poor company all round.
> [...] i'm using the latest..
As always, an actual version number would be more useful than your
opinion of what's "the latest" today.> Ignore a potantial exploit into my system seems not smart [...]
It's not "a potantial exploit into [your] system"; it's another
(potential) vulnerability if your system is already seriously
compromised. As it says in that cited thread, "If someone can
overlisten to that traffic, then you're already in big trouble."> [...] Obviously netgear takes security very lightly, [...]
Or, at least, it pays little attention to problems like this, which
present miniscule actual threats, but do disturb many users.
