cdysthe's avatar
cdysthe
Virtuoso
May 07, 2017
How to check firwware version on my CM600?
Hi,
My ISP, Comcast, are as I understand it updating my Netgear CM600 modem. But if I would like to see which version of the firmware is running on my modem, how would I be able to do that?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello cdysthe
    You should be able to log into the modem by going to 192.168.0.1 then use admin/password to login then in the top right hand corner of the page you should see the FW version.
    DarrenM
