KManis's avatar
KManis
Follower
Oct 02, 2015
I am having problems changing the password on my CG3000D router
I have tried using the default gateway but it won't load up on my computer.  I have 2 people who have hacked into my router and are riding piggy back on my wifi.  I want to either change my password or block thier ISP's which I have.  My router is not compatible with the netgear genie for password change, but I have it to check who is on my signal.  Any help out there?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Kmanis
    Doing a factory reset should let you log back into the modem with admin password defaults then you can redo the wireless password to keep those people out. Hope to hear your feedback
    DarrenM
  • How do you do a factory reset? I tried to change my password on the website, but now I just can't login and can't access the website, for routerlogin.net ...
    • DarrenM's avatar
      DarrenM
      DrShelli
      There is a small hole on the back of the modem you just use a paper clip to hold it down for 10 sec then it will factory reset.
      DarrenM
