Duggs
Jun 24, 2018Tutor
I can't connect iOS to Brother printer
Hi all, I’m desperately trying to connect my iOS device to my Brother MFC-J625W printer. There is already a Windows laptop connected with a USB cable and by wifi to the printer and a C7000 Night...
schumaku
Jun 29, 2018Guru - Experienced User
Duggs wrote:
The printer, the laptop, and my iOS device are all on the same Wi-Fi network.
I can detect the printer on my iOS device, but when I try to print I get a message up saying it cannot connect and that the wireless routers ‘privacy separator’ needs to be disabled.
Coming back to the OP initial post - I would not wonder any second if the C7000 (unknown firmware version) has a problem with the transparent communication (Multicast, Boradcast, ...) within the same wireless and/or between the different WiFi/radio interfaces and/or the GbE LAN ports. Beyond of updating to the current firmware (options might be limited of the Cable Modem is under the Cable ISP management) - this is something Netgear must look into.
michaelkenward
Jun 30, 2018Guru - Experienced User
As you say, the ISP has to update firmware on that device. Neither the user nor Netgear can do it.
I still think that has nothing to do with this issue.
In all of the talk of resetting various bits and pieces, I see not suggestion of a modem/router reset. That would eliminate any possible "memory issues" on the part of the modem/router. But that too is probably not the issue.
